A question re: Negative feedback.
caps
Australia
One thing continues to baffle me somewhat:
With a UNbypassed cathode resistor, we see that as the grid voltage increases so does the voltage drop across the cathode resistor.
So with conduction through the tube, we have a negative going plate and a positive going cathode. This is said to decrease the conduction through the tube. I think I got that right, I hope.
Now, how exatly does it decrease? A negative going plate, a positive going cathode.....I want to understand how the electrostatic field actually decreases, the nuts and bolts of it so to speak.
Additionally, how does one calculate the amount of NFB? I see references to many designs using X amount of NFB, so there must be a way to measure it ?
Thanks very much.
Ok, after some further thinking...
Im thinking the , lets say, a larger voltage drop across the cathode resistor makes the grid less positive ( in relation to the cathode), hence this reduces the plate current? Of xourse the same theory would apply inversely.
hehe, I think I answered my own question, emphasis on "I think"! :shock:
However, how does one control it , is a question that still remains. Just changing the cathode resistor value couldnt be it, youd stuff your bias point...
So, there has to be a way to control it and measure it no??
I seem to remember something about increasing a plate resistor value will lessen the effect of NFB. Maybe this is the way? Of course, this would also increase the amplification...hmmmmmmmmmmmmm.....
> how does one calculate the amount of NFB? I see references to many designs using X amount of NFB, so there must be a way to measure it?
Measure gain. Apply feedback. Measure gain. Difference is amount of NFB.
In this case: with and without cathode bypass cap.
And I'll tell you the answer: for most happy tube amps: 4dB to 6dB NFB by omitting the cathode cap. As you say, any attempt to get a very different answer "stuffs your bias", unless you go to some much more complicated plan.
