buildafriend
Hm.. the problem is the most persistant in the amp nearest the toroid. Ill try it and see what happens. How can I shield it? I've never shielded a toroid before.
sr1200 said:dunno if you can shield it, I had this issue with my 4 ch unit w/ ps inthe same case. I had to point the part of the torroid where the wires come out to the back right corner (the torroid was IN the back right corner) for the buzz to go away on the 4th channel.
3nity said:http://www.don-audio.com/trafo-shield
LesPaul said:Another newbie question...
Can't get my head around the grounding issue. Do I connect all the input XLR pin 1 together to star ground? And the output XLR pin 1 to ground on one of the terminal blocks on the PCB?
This is my first build...
