Access-312 Build Thread
Did anyone build this with DOA sockets available in Europe? Farnell, RS, etc...
Digikey is charging alot for shipping to Europe just for these sockets.
look at the specs at the mill-max and look for something available in europe.
I never thought about it before.
Thanks for tips. Tried finding something similiar at Farnell, but their selection of sockets is a little limited. Will check out whistlerock, those fit the board nicely?
assuming shape as the evening wore late
atticmike said:
Can you tell how much this build needed again?
17.5 or 18 V dc?
I have used 17 V for my access-312. Seems to work fine, and with a good amount of headroom (at least in my opinion) ::)
I used EA2622, EA2503 and gar2520.
Almost finished my second 4 channel! Love this thing ;D
sr1200 said:
The pins from whistlerock fit exactly, no drilling needed.
Mine don´t :-\
Strange.
Maybe we misunderstand each other, we´re talking about sockets, right?
I´ll just order the ED5021.
Want to get this one going :D
Yes, I know what sockets are ;)
Don´t want to be a PITA here - but this is not correct.
I´m sitting here with sockets from whistlerock and the Access-312 boards in front of me - and there is no way to get them into the holes unless I drill them bigger or shrink the sockets about 0,5-1 mm with mind force.
Its just sockets - so really no big deal, but as long as this info is not correct, I just want to point it out. You might have another revision or something, I don´t know, but they sure as .... don´t fit my boards.
Unless WR changed the parts they sell since I got mine (about a year ago now), I had no issues.
Sorry if my post sounded condescending, just didnt know how else to describe it.  :-[
Was trying to see if i had a pic of the sockets from my build but all the pics have the DOA's plugged in.  I do remember them being a tight fit, but not so tight that that they wouldn't fall out if i turned the board upside down without soldering them.
EDIT: as long as you have conductivity after you adjust the hole size you should be fine.
Hi guys unfortunately Whistle rock changed his sockets part.
the only way you can fit them is drilling the holes ..thats what i tried and it works.
tip: if you drill the holes when soldering the sockets insert them in a op-amp to make sure that they sit right.
Good luck people.
Guys i still have 4 boards left in already packed ready for shipping.
Remember last 4...im asking 85$ shipping included.
Thanks.
Whistlerock PSU
Do you think it'd be too much if I turned the 12V rail down to 6.something V ?
Also, how do I have to turn the trimpot in order to have it lowest possible for the first power up? ccw?
Other than the swap of R4 to 100R and R5 to 10k, everything's correct of the V2 bom?
Did you actually finish the bomV3 @3nity?
Good luck people.
I'm not sure where you got that info but the truth is that I never changed the sockets.  I've been selling the exact same MillMax part since I started offering them on my site.  They are a press-fit kind with little ridges to dig into a 0.078" hole.
Mike
atticmike said:
Whistlerock PSU
Hey Mike,
Did you get my email?
Mike
