Some pics of my dilemma... iphone pics, best i can do right now
3nity said:Hey.
This build is pretty straightforward build if you follow the BOM.
To answer some questions i will update the BOM.
Thesystem i suggest you take a look at the Meta for some info before starting something that might help you a lot its looking at pics.
But here are some light to your questions:
1- 10K reverse pot 2.50$ at Smallbear good quality.
2- psu adjust voltages: read the meta and do some research.
3- There are too many power transformers so you better look something at RS-Farnell.
4- EA-2622: you need a 150K on RC, 10K at R7-R6 and 220pf at C8.
5- F2UEE are the pushbuttons to go on the access-312...
6- LED, any LED will do the job if it fits you front panel...you solder it to the lugz on the top of the switch.
7- Sockets are there so the op-amps sits on it ..it makes things easier.
8- Gain 1-2 are there so you solder the wires for the pot..you can use molex headers.
9- yes.
