hi all! I'm posting here in the hope, that someone can help me out with my problem. I posted this also on the access 312 whitemarket-thread, where jorge aka. 3nity really helped me out a lot. thanks again!
there is still one problem left with my access 312 build: I use (or want to use) a stepped gain switch ( http://classicapi.com/catalog/product_info.php?cPath=51_133&products_id=237 ) for input gain control, but I can't get the switch to work, no matter what I try.
everything else on the pre works as expected (pad, phase reverse, +48V thanks 3nity).
input xformer: 2622
output xformer: 2503
doa: gar2520
the preamp is putting signal through from input to output. when a 1k signaltone is applied the amplification from in to out is 22dB.
unfortunately, when i turn the switch absolutely nothing happens...
does anyone have had a similar problem or have an idea where the problem could be??
pics here: http://www.groupdiy.com/index.php?topic=43484.msg587674#msg587674
thanks,
andi
