Thank you, and thanks for all your helpful posts I have been reading about this project. Looking forward to building! Will post an update soon maybe next week. I am using the Capi transformers. Eventually after it is working I want to redo it with the Cinemags but just want to get ‘er running first.Solid wire can snap if bent too hard.
What I do is buy multi conductor 6 or 8 wires...there you go..
It’s not a for sure thing, I’m going to build it with the CAPI’s first and get it running, but a friend who’s built a lot of these recommended some particular Cinemags to me which might help gain staging them without having to use the pads. (He also said they sound better but that is of course subjective.) I mostly record instruments so I don’t need a ton of gain. The 3124+ for example is so super hot. Always have to use the pads. I like recording with some saturation a lot of times so having some attenuation might be nice, he said these transformers knock the gain down a bit from stock. Or maybe I’ll just end up adding output attenuation with the CAPI transformers like my CAPI preamps have. I have read in the thread where folks have done that on the output with a resistor pot. Hope I can get to this soon. Have a lot of “real” work to get through this month unfortunately… Excited to build it though.An why would you do that?
Cinemag transformers are good but they aren't better than the CAPI transformers.
CAPI transformers are exact clones of the original API transformers
Ha. Noted. He's actually a great and fairly well known engineer/DIY person who I will refrain from naming here. Anyway, glad you guys think the transformers I have already are good, and I'm looking forward to hearing them in this build! Anyway, I'll post back with progress and if I have any questions coming up.It's time to stop listening to your friend.
My 2 cents
1. At C3 and C4, but are ceramic capacitors ok to use in these spots? Pic attached. Most people’s builds here I see have film caps like Wimas. Does it matter? Forgive my ignorance…
2. Same at C8 and a few other spots. Does capacitor type matter as long as the voltage ratings and values are ok?
3. At C6, I don’t know what to do. He included a 470uf 25V caps which are too large diameter to fit, so I have to order something else. BOM says any values between 250-1500uf 4~16V will work, , but what is the best, most standard choice for C6 in this circuit? Which one should I choose?
4. I am using the Capi gainswitch pcb’s which create a resistance value of about 25k. I found a post from another user who said he used resistor values in R4 and R5 of 25kohms and 250ohms to matchup best with his Capi gainswitch resistance.
5. I’m using 1/4 watt resistors in this build as I usually do for low voltage preamps. Is that ok? Should I have used 1/2 or 1/3rd watt? The guy who sold me the kit bought 1/4 watt for everything.
6. This may or may not be answered in this thread which is fine, but I’m using Collective Cases’ DC Filtering PCB to accept external switching PSU power. The pinout of the PSU is in the picture below. It is; Pin 1. XLR Shell 0v, Pin 2. COM 0v, Pin 3. +16V, Pin 4. -16V, Pin 5. 48V. My question for anyone who’s built with this PCB before is; Do I have the pinout basically correct for the board? Would “COM” go to star ground, or should “Shell FG 0V” go to star ground, and what goes into the very last hole on the right on the DC Filter PCB where I have a question mark?
Also the guy I bought the “kit” from purchased the wrong output transformers… He got the ones meant for vintage API cards instead of the ones meant for these PCB’s. So they have weird mounts on them like this: Classic Audio Products, Inc.
I suppose if I mounted them somewhere else in the case they could potentially still work… Should I try that? Or should I just try and sell these ones and buy the right output transformers… It sucks because these are expensive. I wish I had known before he sold them to me. So far, no response from CAPI asking if I can trade them in on an email…
Man, thank you so much for all the help. I really love this place. Ok I will do all that. Really appreciate your guidance! I’ll be sure to post back when the build is complete. This has been a fun project so far and this thread is invaluable & full of information for anyone interested in making one of these boxes.The caps used are not standard ceramic capacitors, by the photos it's easy to see they are ceramic multilayer C0G/NP0 capacitors, those are really good. Keep them
"C0G (NP0) ceramics offer one of the most stable capacitor dielectrics available"
All good, same as above
I'm sure if you are a bit creative in bending the legs of the 470u cap that you will be able to fit it there.
The value is fine, I would use that one
use that
1/4 watt is enough
COM goes to Ground (0v)
Shell and Chassis goes to the big pad with the "?"
Man this is DIY,
those are not "wrong" transformers, they just have a different mount.
Do DIY, be creative and build a mount for them to use in this project/PCB, use your skills to make them work,
problem solved
Yeah, like Whoops said, these trafos are correct in terms of function. Just solder wires to the pins and run the leads to the PCBs. Keep the trafos pretty close to the PCBs when you mount them.Also the guy I bought the “kit” from purchased the wrong output transformers… He got the ones meant for vintage API cards instead of the ones meant for these PCB’s. So they have weird mounts on them like this: Classic Audio Products, Inc.
Thanks! I actually managed to figure out how they'll fit into the PCB's, and using some cardboard shims on the sides of the trafos on the top of the PCB's as spacers, there is now enough clearance on the bottom for everything to be kept clear of the case bottom using 6mm standoffs and still plenty of clearance for the case top to go onto easily without touching the top of the trafos. I'll post a picture when I'm done but it will work! Still waiting on some resistors and the opamps in the mail, but coming together.Yeah, like Whoops said, these trafos are correct in terms of function. Just solder wires to the pins and run the leads to the PCBs. Keep the trafos pretty close to the PCBs when you mount them.
I mean, hey, if Jeff will trade them in for others and you want to do that, that's fine, too.
The board has 8 holes and the trafo only has 6 pins.
I'm not that good with schematics...
2623-4 | Access PCB | |
Orange | Brown | |
Red | Red | |
Black | Orange | |
Brown | Yellow | |
Green | Green | |
Blue | Blue | |
N/C | Violet | Not connected |
N/C | Gray | Not connected |
Man, amazing. Thanks so much. Yeah, I'm definitely learning a lot as I go, about it all... I have a basic understanding of schematics and can follow them to a degree, but in a case like this, I was hoping to be able to simply matchup the leads of the CAPI trafo with the original but I realized didn't know which trafo was in the original design... And then didn't understand the diagrams well enough to know how to match them up. This is so helpful thank you.Because the board was made up for the 2503 transformer, which has 3 secondaries, while the 2623-4 only has 2 secondaries.
In the 3 secondaries in the 2503, 2 were used for the audio output and 1 secondary was used to feed a VU meter.
So on the 2623-4 with only 2 secondaries, you use both for the audio output in the same way as the 2503 but you have no feed to connect a VU.
If you dont want a VU, like myself, then it's totally fine as is, but if you need a VU then you have to use an active electronic buffer circuit for that which is NBD.
Compare the Diagrams/layout of the 2503 to the 2623-4 so you understand this
Well, schematics are really easy to read and to follow, specially in a case like the 312 preamp which has a really really simple circuit, so starting to read this schematic it's a great way to learn.
So you should take the opportunity while you're doing this project to start learning and understanding basic schematics.
This is the color correspondence between the 2623-4 and the pads on the Access 312 PCB,
again, check the access 312 schematic and both the 2503 and 2623-4 diagrams to understand this:
2623-4 Access PCB Orange Brown Red Red Black Orange Brown Yellow Green Green Blue Blue N/C Violet Not connected N/C Gray Not connected
