crazydoc said:I'm sure many of us would be interested in helping with this. There's a guy at Gearslutz (maybe it's you?) that's interested in doing this too - you should get together to avoid duplication of efforts.
http://www.gearslutz.com/board/3911056-post1785.html
It would be nice if TNC were to take an interest in this too. :
Steve Hogan said:We have taken apart some Chinese toroids and found out that the core in those units, which is supposed to be a single continuous strip of grain-oriented silicon steel, was actually made from multiple scraps welded together.
The DCR built into the coil will effect its Q. Low DCR makes for less damping, so ringing and resonance problems might occur.
rodabod said:Steve Hogan said:We have taken apart some Chinese toroids and found out that the core in those units, which is supposed to be a single continuous strip of grain-oriented silicon steel, was actually made from multiple scraps welded together.
Eek!
tarnationsauce said:FYI The 81's transformer is different than the one in the 73 & 84.
I took a look at them and evidently they are custom transformers specifically for these preamps (looking at the model numbers).
(info off transformer labels)
Transformer model numbers "Mp81" and "Mp73/84". Brand: YTDZ Mianyang Yingtian Electron Co. LTD http://www.ytdz.cn
Mp81
50/60Hz
0--115 0--115
15--0--15 0--26
0--26 0--45
Mp73/84
50/60Hz
0--115 0--115
15--0--15
0--26 0--45
It looks like the only difference is the Mp81 has an extra 26v tap. I see no VA ratings.
rodabod said:Can anyone see why they bothered with the two 26V secondaries? They both seem to be providing +24V after regulation.
I was also wondering if it might be possible to use an off-the-shelf 120+120:15+15+15+15 for those who are not able to buy from the USA. Off the top of my head, that would give 15+15 for the bipolar 12V rails, 30V for the 24V reg. (heatsink the reg.), and 45V for the phantom power.
1) The current ratings are on the schematics (? accuracy)Steve Hogan said:tarnationsauce said:FYI The 81's transformer is different than the one in the 73 & 84.
Mp81
50/60Hz
0--115 0--115
15--0--15 0--26
0--26 0--45
Mp73/84
50/60Hz
0--115 0--115
15--0--15
0--26 0--45
Thanks for the heads up. I could design 2 different transformers or maybe just have one and wire the 2nd 0--26 Volt secondary in parallel with the first when used in the 73/84 clones.
For me to design a replacement transformer, it would be helpful for someone to make some accurate measurements of the existing transformers for me as follows:
1. The overall height. Since this is a 1 RU box, I also need to know the maximum height I can make the replacement transformer.
2. The overall diameter. The pics show quite a bit of space around the transformer, so I presume a larger OD would be fine.
3. The DCR of each winding, including separate measurements of each primary. These resistances must be measured with the transformer disconnected from the circuitry. (easy if the trafo is connectorized).
4. The open circuit (disconnected, no-load) voltage of each winding when the primary voltage is held at 115 Volts with a Variac or whatever.
5. Mounting details -- does it have an epoxy center or does it just use rubber washers and a round disk to hold it in place?
I would make the replacement transformers 50/60 Hz. (Low flux density at 50 Hz requires 20% more turns or core than 60 Hz, but the resulting 60 Hz operation has even lower stray field)
I would think that a 120V/240V nominal primary would make more sense nowadays since utilities are trying to hold voltages closer to 120 than 115 to lower losses. With more reserve, the transformer will have better regulation than the original(s). I would design it for +/- 10% (108/216 to 132/264 Volt) operation. If we really want to get carried away, a faraday (copper foil) shield between primary and secondaries will prevent capacitive coupling of AC line noise to the circuitry and the chassis.
In the published schematics did I see capacitors intentionally wired from the IEC input connector line and neutral to chassis? EEK! What a way to make more Pin 1 problems with excessive AC chassis currents. The faraday shield is a much better approach.
