ben_allison
Member
- Joined
- Aug 15, 2010
- Messages
- 15
Nice! I'll be using it with an SM7. I don't think mic-noise will be an issue.
About an additional 0.6dB NF for 300RPRR said:> I rather think that R3/4 22R would increase noise compared to a nominal 300R
Can you calculate it?
You don't. I'm on another forum discussing this and I've offered my own poor take on the subject.> a THAT1510 preamp optimised for ribbons w/o P48V etc.
If you have that THAT, why would you need a boost?
All good points, Guru PRR.> is the ribbon safe if one line is shorted
Fix your cables.
Ribbons, bad cables, Phantom in the room..... BAD mix.
Does this mean you recommend NOT having C1/2? My instinct is not to have them.C1 C2 will limit long-term unbalance current but can dump a BIG thump, and that's all it takes to throw a ribbon out.
Of course. But what sort of zap can a ribbon stand? Which ribbon? You can work out stored energy in caps and integrate the pulse on a storage scope to measure the zap. But what does that tell you? I'm not looking for opinions as much as experience. OK, guru opinion is probably backed up by experience in similar fields so I'll have the opinion too. But it's hard to get someone to try their vintage 4038 on an experimental circuit ;D But if someone has already done it ...Spend 3 dollars and 20 minutes twisting one up, put a cheap 600:600 where the ribbon mike's secondary would be, 'scope that, and then drop a screwdriver on one Phantom line. Try-and-fry is really a better path than asking around for various opinions.
PRR said:Olson advocated hi-Z loading, and this has been the custom until recently. Olson wasn't perfect, and custom changes.
ricardo said:The mechanical 'response', impedance plot and Ri of the preamp all interact. But the efficiency of ribbons preclude significant 'electromechanical damping'.
You can see the relative significance by looking at the impedance curve of the mike.ricardo said:But the efficiency of ribbons preclude significant 'electromechanical damping'.
Thanks for your comments PRR. This started in micbuilders. One ex-Shure member builds his own ribbons from scratch and is considering building it into a mike so he can damp the ribbon to suit the virtual earth.
I'm trying to work out why my offset adjustment dun wuk. And I wannabe a SPICE guru too.PRR said:Isn't it quicker to build it than to SPICE it??
I sorta realise that but ANY transistor model is new to me.For a model, use any good-gain transistor of the right polarity. The differences between them are not quantifiable in SPICE.
Surely SPICE allows hfe & Vbe (vs Ic) to be varied in the model?PRR said:With any two instances of the same SPICE transistor, at the same bias, there is NO offset because the two "parts" are identical to the 13th decimal place. If you want to trim offset you probably have to insert a 0.005V battery in one Base. (Some libraries allow parameter tolerances; this is probably more trouble than it's worth.)
Reply #246 18may11I don't recall an offset trim; your invention?
