f0m3 said:Ok, thank you.
So what about the 4 jfet thing. Any suggests?
Provided they run each at the same current than the singles. Simulations lead me to think it is feasible within the constraints of P48.Winston O'Boogie said:1/Doubling up on another pair of the same type J-Fet in parallel would lower noise by up to 3dB.
And that's about it. IMO there are other (simpler) ways for restricting Vds. For the rest, Miller capacitance is not a real issue and the output impedance, already excessive in the original, is even worse.2/Another possibility would be a pair of suitable J-Fets to cascode the K170's. Not so much for the decrease in capacitance and extended top end, nor for any elimination of distortion at high frequencies, because the source z is low here.
But because the K170 is best limited to 15V or lower on its drain to prevent against any possible leakage on its gate.
abbey road d enfer said:Provided they run each at the same current than the singles. Simulations lead me to think it is feasible within the constraints of P48.
3/ Add a pair of source followers to the output to lower the impedance and provide a better source to the following mic pre. From the beginning I felt concerned with the fact that the preamp sees an unduly high source Z.
I've simmed a version with emitter-followers added. The raw output Z is less than 5 ohms. Needs build-up resistors for properly driving xfmr-based preamps. I know some use low-power opamps. I believe that would be noisier than a simple emitter-follower.
I've layed out a PCB. Placed the order today. Size 65x28mm, designed to fit into a Neutrik NA-housing. We'll see...
Thanks for your generous offer. The board is layed out with LSK389's, which I find incredibly difficult to get. The only source I found doesn't want to ship to France, so I had them shipped to NY where a friend will post them back to me...Winston O'Boogie said:You're the man.
Regarding doubling up on input pairs, I was thinking they'd each have separate ballast resistors for current sharing. Besides the output impedance issue which you've addressed, the source impedance the J-Fets see is not the best for noise so another 2 might help. Anyway...
If you're using K170's, do you need a few? I have some on hand I can send.
abbey road d enfer said:The board is layed out with LSK389's, which I find incredibly difficult to get. The only source I found doesn't want to ship to France, so I had them shipped to NY where a friend will post them back to me...
Meantime I have ordered 2SK369's; I'll have to twist leads...
I've laid the board with separate source resistors
That was the original plan from the start.Winston O'Boogie said:Very cool.
So just to clarify: Are you saying that, after swapping out a possibly faulty LSK389, you ended up with 2 X LSK389 (2 pairs in parallel) ?
Correct. Actually there's a small noise contribution from the source resistors (68r in each) so the actual source Z seen by the FET's is 268r. That's why I say the measurements are too good to be true.I'm guessing you mean that a 2nd pair cancelled out the circa 3dB noise increase of the diff pair to get you back to the 1nV/rtHz of a single transistor yes?
abbey road d enfer said:Checked headroom and THD...
...After all it's not so bad for a circuit with so little NFB. Doing what I can to comfort myself...![]()
Whoops said:
kato said:I was on the cusp of buying a FetHead, so thanks for the internal pics.
kato said:I'm thinking Artur Fisher's Bumblebee Ribbon Booster might be a smarter place to direct my funds.
That's the reality of business. A manufacturer typically operates on a mark-up of 4; that means that the product is sold to distributors at 4 times the price of raw components. The Fethead is sold ex-works at £35 ($45). $11 seems to be correct for component cost.kato said:Yikes. That's a bit disturbing for a product that costs $100.
I have a Fethead, I didn't find it particularly noisy, although I found that the noise dependance on source impedance was strange. IMO the main issue with Fethead is that its performance varies too much with the impedance of the preamp it is connected to.he compares the FetHead to the CloudLifter, you can hear more noise from the Fethead, through YouTube, even without headphones. (!)
Whoops said:All the circuits will be simple, even if some more than others
Whoops said:€149.00 excl. VAT, seems pretty expensive.
Whoops said:Why don't you use this thread and others that exist here in GroupDiy and build a few units for yourself for almost nothing?
abbey road d enfer said:That's the reality of business....
kato said:What do you think of the KlarkTeknik MIC BOOSTER CT 1. At $29, it's undercutting the spork out of Cloudlifter, FetHead, Dynamite, Launcher, SS-1, Radial McBoost, Cathedral Pipes, etc.
What do you suppose is inside? 16¢ worth of SMD components? Or the PRR circuit from 2005.
I dig the inline form factor of the Fethead and the CT1.
Whoops said:Well it's a Behringer product, probably a clone of something around, released for an unbeatable price.
Might be good
Behringer stuff works, there will be smd for sure, they want to sell it for cheap but are not dumb, they still make it profitable so yes SMD
