[quote author="Samuel Groner"]
Did you verify this with a suitable output load (e.g. 1k)? Not sure what current gain the phase splitter got but the load might get trough and increase this frequency.[/quote]
Just did a simulation with 1k (I usually use 2K): -3dB rises to from 11.4 to 13.5 Hz. 1u still gives 19.7 Hz.
Would the 2SK170 still be superior to the 2N3819 as a source follower?
Noise wise for sure. Note however that you actually would like to have gain as early as possible. This would ask for a different output stage topology though. Personally I'd go back to the Dorsey circuit I think (
miccircuit.gif). Or do you see a specific advantage of your circuit?[/quote]
I was a little curious about using a phase divider on the output. It seemed to be such a simple solution, but then again maybe there are reasons why it's rarely done.
So, maybe I should just go back to the Schoeps/Dorsey circuit. My initial mistake was using the hind part only, as I didn't need an excessively high input impedance. Around 100k would be enough. (Some transformer ringing wouldn't be so bad, as it would actually give some "free" treble boost, which you often need with ribbons anyway).
And how did you measure the microphone noise? Looks like a relatively difficult thing to do.[/quote]
I just used my ears, made some recordings and compared to other mics. The difference was distinct. The mic's self noise was spec'd at 14 dB-A, which was about correct. Maybe my ears are more sensitive to noise than most peoples, I don't know, but I find that I can tell self noise with some precision by just listening and comparing to other microphones. Below 12 dB-A it becomes difficult, of course, and it's impossible to determine exact noise figures in the single digits using this method, due to room noise. Figures above 18 dB-A are really easy. Most passive ribbons are about 18 dB-A on an super low EIN preamp. Incidentally, I had a passive ribbon mic using pretty much the same ribbon motor to compare to.
Yeah, maybe the 22 nF at the output are a little high, although, according to spice, the frequency response remains flat to several hundred kHz.
Frequency response is not the problem, but the capacitors present a load to the output stage, causing frequency-dependent distortion.[/quote]
Thanks, Samuel! I guess there's still a lot for me to learn. Not being educated in the field, I probably rely on simulation too much. I think the MXL version of the Schoeps/Dorsey circuit uses 22nF capacitors on the output.
http://www.sdiy.org/oid/mics/MXL-603S.gif
