ADA 8000 AND GREEN PRE MIC
maxmoioli
New member
Italy
HI THERE...
SOMEONE IS SO KIND TO POST THE GERBER FILE AND THE COMPONENT LAYOUT OF THE ORIGINAL PETER CORNELL GREEN PRE MIC??? BECAUSE I'M BUILDING A 8 CH PRE MODIFING THE ADA8000 (PUTTING THE GREEN PRE MIC IN THE PLACE OF BEHRINGER)...
I HAD THEM FILES BUT I DIDNT FIND ANYMORE...
THE 1176NEVE.TRIPOD IS CLOSED AND I DONT KNOW HOW TO DO...
REGARDS...
[email protected]
I'll say what everybody else is thinking...
You need to fix your caps lock key and try typing that again!
:p
Hi there..
someone is so kind to post the gerber file and the component layout of the originaal Peter Cornell Green Pre mic??? Because I'm building a 8 ch pre modifing th ada8000 (putting the green pre mic in the place of behringer)...
I had those files but I didnt find anymore...
Regards...
[email protected]
RIGHT NOW???
Any help?
Unless you're going to use another case
i can't see you getting it small enough to fit
try checking the grp d.i.y. account in the meta
[ not sure if it's there or not , ]
everyone else is thinking:
WHY?
those are decent mic amps very similar to the greens. don't bite off too much, build a pair of greens and compare, swap out some caps in a channel of the ada box
Here is the most up to date info for the Green Pre, as far as I know.
http://www.mendelt.nl/greenpre_V14/
