This is one way of doing it, but the calculations I've written before surely will help you narrow down the possibilities.Rob Flinn said:Abbey thanks for that info. Are you saying that one has to buy a load of bobbins & just experiment to see if you can fit the number of turns required ?
It all depends on the circuit it is in. Very often, LC based EQ's use padding resistors in series with the actual inductances to provide the desired Q.Also what is too high a d.c resistance considered to be ?
But if the Q is already too low (too high DCR), there are only two solutions: make another inductance with a larger or higher AL core or accept the fact that instead of +/- 12dB, the range will be +/- 10 or 9...
