Aguilar DB750 PSU transformer damaged
melmsmidth
Active member
Madrid
Hi everybody, I have a friend with a problem with his Aguilar DB750. As soon as he switches on the amp, it enters protection mode and obviosly there is no sound.
The unit right now is at a reliable repair shop here in Spain, and he’s been told that the problem is in the power supply toroid transformer and needs to be replaced. The problem is that this is a discontinued model and a custom transformer is used and Aguilar (now Korg) doesn’t have spares anymore so the technician who saw it says that we need to order a custom one from someone but we don't know the exact specs needed.
I tried to contact Aguilar but they sent me to the local dealer ("Please contact the Aguilar distributor in your country who will be better equipped to assist you.") The local dealer doesn't have any info or spares, of course, since it's a discontinued model.
So, we have the schematics (attached) but It's out of my knowledge to find the current and voltages required in all the windings. Can it be calculated based on the schematic? Specially the power and Valves sections. If we figure out the required scpecs we can order a custon wired transformer and try to repair it.
Any info or recommendation is greatly appreciated, as I said I don't have the amp with me right now so i can't run any tests or checks, but feel free to ask any questions or advices.
Thank you very much in advance!
  • aguilar DB750 schemos080409.pdf
    745 KB
  • db_750_specification.pdf
    30.2 KB
Hard to believe that the pwr xfmr would trip the output circuit, a blown fuse yes .but not the output relay.
Get a meter on that xfmr while the secondary leads are disconnected.
Thanks CJ. Yes, I think I need a little more information about the fault since you are right.
The truth is that some people have had problems with the input transformer shorting out in this amps... but I will tell my friend to bring it to me and see what I can do by myself, it's still on the repair shop so I can't take any measurements right now.
if one of the legs of the secondary were open and you lost a rail, that might trigger a fault,
I think I'll have the amp with me in a couple of weeks. As soon as I can confirm if the problem is the transformer I'll let you know, I should have started there ;)
Thank you both!
Well, finally I have the amp here.
I was misinformed, there is a circuit breaker in the mains switch that jumps inmediately to the off position when you try to switch it on, so it’s not the internal protection circuit.
I have some more info on the transformer so now I know the voltages required although I still miss the amperes needed for each winding.
I measured resistance on the primaries and secondaries. Don’t know if my DMM is good enough for this, but all the windings have very small resistance, a few ohms, less than 1 ohm in some cases. Can’t tell for sure but if the circuit breaker is working I assume there is some kind of short.
There is a thermal fuse in the transformer too, that seems to be open since I have an open reading in my DMM. Maybe a short in the trafo leaded to a fail in the thermal fuse?
Anyway, it seems that I need a new transformer but as I said I dont know the amps required for each winding. I can send it to someone who makes them here in Spain but, any tips or recommendation before I do it?
Have you checked the voltages though on each secondary?
The trafo came uninstalled, but since the circuit breaker trips I presume the trafo will not receive any voltages.
I can mount back the transformer to check myself, but should I bypass the circuit breaker? I don't feel confortable with that, I don't have variac or anything and doesnt feel safe to me...
Any thoughts?
Any thoughts?
Yes. disconnect the secondaries of the transformer. Then measure the output voltages of the transformer as has been suggested.
The transformer might be o.k. and something else is causing the circuit breaker to trop.
You can also check the circuit breaker itself as it may just be bad, while it would be low on the list to check, they are not impervious and can eventually fail or develop a fault.
