untune
Hi all,
Relatively new here, built a Bo Hansen DI and a few bits of modular synth stuff and I'm looking to tackle something bigger. I was going to make my next project a valve mic preamp but I happened upon this Akai R2R - it's very similar to the M7 and M8, and the various Roberts decks that are often used as monoblock amps, except the valve compliment is quite diferent and consists of 2x 6AU6, 1x 6BQ5, 1x 6AR5 & 1x 6X4. This particular model is seemingly quite rare, perhaps having more in common with the earlier Terecorder designs but having a more unusual tone adjustment setup. I'm not sure if there's a Robers equivalent but the 900 series seems to look very similar. The VU meter is dead but I will replace that if I can source a decent, vintage one (which is proving difficult - if anyone has anything spare please get in touch!)
Anyway - I've not tackled a valve project before and was hoping some of the more experienced amongst us might have some helpful input and guidance. I've managed to get hold of and clean up the schematic, and the first port of call is going to be eliminating the unnecessary recorder-related components from the circuit. Any help in what can be removed and what needs to stay would be grand.
First observations:
From what I can see:
I'm hoping to end up with a decent microphone preamp that will most likely be used as a line amp for synthesizers/instruments etc. Goals are:
I'm sure there's more but there's a lot in my head at the moment. I'm starting to think the best option is to tear the whole thing down, clean and replace everything that needs it, then build it back up from scratch without the unnecessary parts. I'm more interested, given my lack of experience with valve circuits, how the core preamp circuit might be improved or altered given that the valves are different to those found in the units that are usually modified. As I understand it the pentodes have considerable gain and may be a little too much. Opinions?
I'll attach the diagram and also a modded diagram from a project I managed to find on another forum, from a similar machine with the same valves (can't remember where, sorry) which has been whittled down to a more basic circuit. Might be a good starting point if nothing else.
Any help is vastly appreciated
Cheers!
First observations:
- A test showed that, during recording, there is a significant treble boost which took a high cut of around -28db to roughly match the same signal recorded through a Warm Audio WA12. I assume there is an IEC treble boost being applied which also comes through the output jack. I'm not sure where in the circuit this is introduced.
- The tone controls are not active during recording, only playback - however, the switch (bass-flat) does introduce a nice bump somewhere around 100Hz when set to bass. I'd like to keep the tone control option present and perhaps have the option to bypass the pot control.
- Noise and whoosing when adjusting volume. I'll put this down to the fact that I've not yet recapped it, and the valves might need swapping.
- SW1 can be eliminated, and things can be bridged as if the deck was set to 'record' mode - not entirely sure what else can be bridged though. Similar situation with SW3.
- All tape mechanism electronics can go, power/voltage selector etc can go - 3 way power/amp switch can be replaced with an ON-OFF DPDT with a fuse inline, it'll be operating on UK mains voltage.
- 6AR5 isn't necessary without the tape section? If this is the case I'll need some help figuring out what to take out and how that part of the circuit should look. Oscialltor coil can go, I imagine.
- Not sure what the output impedance is, and the output transformer is unbalanced - would there be any point modifying this for balanced output? Would that affect the speaker out?
- Keep the line and hiZ mic inputs in place. Plenty of old mics that will work with this and I have some vintage lo-hiZ transformers from British tape machines that I can utilise with newer mics.
- Eliminate the useless head output, and (if possible) have a direct input for bass guitar.
- Add a transformer balanced mic input on an XLR socket, with polarity switch and pad.
- Speaker output in place of the speaker, if it would be logical to use this as an amp too (present speaker is 8ohm/4W.)
Cheers!
