does anyone know if the pin and power requirements are similar for an AKG c28 and a C60? I have a power supply that was built for a C28, wondering if I can use it with a C60 without causing the puff of smoke...
thanks
dave
thanks
dave
In fact, AKG made a N6128 supply, which could feed C12, C12A, C28 and C60 mics. It had a switch for different filament voltages. The B+ remained the same. The biggest problem with DIY is that it has a very expensive weird connector, which is different from the mic one. Of course, you could accomodate 5 pin XLR there, and change cable end.
Whatever you do remember that AC701 is very sensitive to filament voltages. It should be dead 4V.
btw, if anyone's still interested, abs. max voltage for ac701 is 120v.
Perhaps it would be easier to just swap the c28 transformer and keeep things simple... Is there anything available that would fit in place of the c28 transformer? Figured Id ask, but seems like a small transformer to be a commonly available thing.
