damien
I bought an Alctron SD202 Passive DI to check what I could get for 20$, it was also the perfect time to check the manufacturing quality of Alctron because I was thinking about purchasing their 1073 preamp.
They claim to deliver "warm, vintage-flavored direct sound from your bass, keyboard, or acoustic guitar." with 103dB s/n.
https://www.alctron-audio.com/EN/Audio-Toole/di-boxes/SD202.html
I received it and was really disapointed because it was obviously not working.
I opened the box and here is what's inside :
As you can see the transformer, is broken and the leads cut off from the terminals.
That's a shame.
So I was thinking about removing it from the PCB, extend the enameled leads and solder it back to check what it's capable of.
And I thought that the enclosure, the PCB could be nice to put a "better" transformer on it.
What would you suggest?
1.Do you think I should forget about it?
2. repair it and leave it as it is working?
3. replace the transfo with something "better"?
Any experience on affordable balancing transformer to replace this one in the 10-40$ range? I checked on aliexpress but it's pretty hard to find.
The only available on the market are Jensen, Cinemag and so on for +100$. There's probably a more affordable brands?
What would you recommand?
Thanks a lot for your insight!
That's a shame.
