I'm happy that you were able to sort it out,
a lot of things can be learned from these small repairs.
Not the "best", but actually the only one: Insert a resistor of about 60 kohm between the soundcard output and the DI input. Load the DI output with a ca. 2k resistor and connect it to the soundcard input.Do you know the best way to measure the frequency response and THD with Room EQ Wizard for exemple while respecting the input & output impedances?
Assuming you know how to operate REW, use the Measure instrument. I suggest you use at least 96kHz SR if your card allows, and an upper frequency limit of 48kHz, so you may see evidence of the xfmr's resonant frequency. In terms of level, you should use about -10dBu.
Seems good to me, as far as measuring impedance, which does not need to be accurate.Hi @abbey road d enfer, I setup my computer and REW as DIY RE explained in this youtube video . I don't have mic pres on my interface, just line Inputs, I use external ones. So do I have to run the test through the external mic preamp with the overall profile as calibration reference or just :
Soundcard Line Out-> 60K Resistor -> DI Line In -> DI Line Out -> 2K Resistor -> Soundcard Line In ?
Yes, that's life... If you want to measure THD, you need a preamp.PS : since the transformer is 20:1 The DI level output is really low to keep the specs "linear and low THD", it's a bit tricky.
Hi So do I have to run the test through the external mic preamp with the overall profile as calibration reference or just :
Adding hot melt may be closing the barn door after the horses have left. A significant part of new product design is surviving abuse during shipping. Transformers are often the weakest link due to their relative mass and weak attachments. Attempting to secure them with just their wire leads is often a source of problems.So it's working as it should! Everything is fine and I put a big blob of hot glue around the transfo to keep it where it should be.
I really wanted to thank you all for your help.
Do you have an idea about the input impedance at the instrument side?
My mistake! DI In , DI out (not DI line In and DI line Out)isn’t the DI output Balanced “Mic Level” out and not “Line Out”?
Im talking about what you wrote about the DI output and not the input
Check the second post of this thread...
@abbey road d enfer and @Whoops Can you please tell me what you think about how this DI performs compared to other higher quality passive DI according to my tests? thanks a lot for your insight
