Forgive me if this is a necropost, but I have more information for owners of RA-100's who wish to improve the sound. And I mean drastically.
I had been using one to power my studio monitors for years, and then swapped it out for an ancient Crown D60. The difference was amazing. Way more detail, sounded much "larger." Not even a subtle difference.
This inspired me to examine the RA-100 schematic at length. I could find nothing in the signal path that would explain the difference.
I tried a few of the mods described earlier in this topic, increasing the value of the power rail stabilizer cap on the power amp board, decreasing the value of C02 and C04 and changing them to silver mica. I removed the core of the inductor. None of this made much perceptible difference. I tried it on only one channel so as to be able to compare it.
Then I ran it past a friend of mine who is more solid state savvy. He looked at the schematic and pointed out that there is an elaborate protection circuit in the output section that could be responsible for nuking the transients. Sure enough, I took my cutters to it and removed the protection circuit and the amp turned into the best-sounding amp in the house. I mean the kind of sound that makes me want to go through my music collection and hear all the little details that I missed before.
I'm sorry that I can't explain the theory better, but I can give the recipe. It's easy enough to do with a pair of flush cutters. I have no fancy measuring equipment, just my ears.
The most important thing is to remove D01, 02, 04, 05, 06, 07 (this is the big step, the amp will start to sound great after this).
For form's sake, I also removed Q02, Q06, R03, R17, R06, R14 (this will isolate the remaining components from the power supply and bases of the driver transistors).
Note: there is a photo floating around where the person claims to have identified the components. I found this photo to be mostly incorrect. The diodes and transistors are well-labeled, but the resistors are identified underneath their bodies. If you want to be sure, you can carefully nudge the resistor to one side to read the reference designator.
Refer to the service manual:
https://audio-circuit.dk/downloads/alesis/Alesis-RA100-pwr-sm.pdf
The amp already has a thermal protection scheme and clipping indicators, so as long as you don't drive the output into a short or ignore the clipping lights you should be fine. It's also a good idea to check (and adjust if necessary) the bias as described in the service manual. Before the mods, one side of mine was in spec and the other 10X too hot. It didn't seem to affect either the sound or the thermals. These things are about 30% heatsink anyway. Even in PA duty, mine have never been anything but cool to the touch.
If you read the designer's circuit theory, you'll see that while the thermal protection circuit is described, the protection circuit that I cut out is not referred to at all.
If your C02 and 04 are still at 220pF, I do think that it's worthwhile to swap them out for 120-100pF. It appears that Alesis did this in later builds. I haven't done this yet on the other side, but I will. The power supply rail cap value increase can't hurt either, while you've got the module out for modding. As for the inductor....I left the core in on the other side and it sounds great.
Anyone who tries this, please let me know if you think it's an improvement. For me, it was a drastic improvement that took the amp from being unusable for monitoring to being my favorite.
