Are you getting that voltage at the tube sockets? Is this a PCB or P2P? Either way, I recommend looking at the Cayocosta layout so you can visualize the flow in your head. If it's P2P, I'm guessing the wiring went bad at the sidechain 12AX7. Something is fundamentally amiss. Posting a pic might clear it up very quickly.soundsactive said:yea, that's why i'm confused. i cleaned stuff up and i'm getting a solid 3.5v at each point so that should feed the tubes fine. however, only the 6aq5 is firing. what are things to look for as to why the tubes wouldn't be heating/glowing?
I'm not an expert, but I built a LA2 w Caycosta's layout last year, and the way I remember it, for the heaters I used one filament (two cables) from the Hammond xformer that gave 6.3V AC. Not the center tap.soundsactive said:ill get some pictures up ASAP. this is all P2P a la Cayacosta's layout already.
Since my power transformer has a center tap on the winding for the heaters, which is grounded, i should only be measuring 3.5v on the heaters, correct? due to my reference to ground/center tap?
