Hi everyone,
I'm working on a build of a dual/stereo la2a based on the pcb (found here on the forum).
EDIT: Just to clairfy, I'm building this dual LA2A into a single Rack case.
I'm designing the face plate and I have some operational questions. I'd like to bring the maximum functions to the front but leave things that are used only once to the back.
On the front of the unit, I plan on putting the Lim Response (R37), gain and peak reduction, +4/GR, Lim/Compress controls.
On the back, I plan on having the Zero adjust pots mounted...
The question is what to do with the stereo adjust pots (R3), every time I use the units in stereo, do I need to Re-adjust them? can I just do the stereo adjust procedure once, set it, forget it and then put a DPST switch on the front that connects the stereo parallel and grounds (terms 6 and 7)? I would just flip the switch when i wanted to move between dual and stereo.
also.....
I will wire R37 such that turning it clockwise will increase resistance and label the Lim Response on the face place "HF Sensitivity"... .does this make sense?
Thank you everyone!
