AnalogPackrat
Dennis,
What audio transformers are you using? Sowter? If you're using the Sowter output transformer (8940) you may be experiencing oscillation in the WCF stage (12BH7). With Sowter output, use 1k grid stoppers on the 12BH7 (read back through this thread--pages around 30-50?). If you're using some other kind of transformers, then ignore this.
Check for cold solder joints around your meter switch, output XLR, output transformer, etc. Also, did you look at your T4b with the cover off and the lights out? Feed in a line level input of music and tell us if you see the EL panel flashing or not.
A P
A P
