Hi again.
Yes, i am glad i sorted out the A-10!!
API wrote:
The output pot works, but i dont get any meter reading.
Also, the switch still pops when i change from GR to +4 to +10.
What output pot? You mean gain? You don't get meter reading for +4 or +10?
Yes, sorry, i am talking about the gain pot, R1.
When i turn it the output level changes, but ther meter just sits still at the far left with no mevement, bith on +4 and +10.
Quote:
Where should R3 and R37 be set??
Is there a standard position??
The wiring of these are correct as well.
RTFM. Somewhere in there it tells you which way to turn them before you start testing it. I want to say its all the way CCW, but there's a 50% chance I'm wrong. Don't have the manual with me at work.
RTMF=Read The Fu***ng Manual ??
That was a new one for me!
I found nothing in my Bloo manual about these to, not even what they were used for!
Does anyone know which way to turn for basic testing??
Are you sure your reading on V1 pin 6 is 230V? That's about double what you should see. Check that R13 and C2 are wired correctly and that R13 is really 220k. Pin 8 is too high, too, but it's probably because of the pin 6 problem. Just for fun check R14, too. V2 looks OK.
Yes, i got a 230v reading here, bad i guess?
Will check the wiring and value of R13 tomorrow and let you know.
Will check R14 to.
Mine acted funny because I had wired R4 backwards. Which way does the needle move relative to R4 when the meter is in GR mode? What's your voltage on the neon (between the neon and R28)? Does the brightness of the neon change when you sweep R4 around?
From memory the meter moves in the same direction as i turn R4 in GR mode.
Is that right??
The voltage between the neon and R28 is about 60 volts, which i think is correct.
The neon shuts down when i am at either end of R4 (at least when its fully CCW), will double check tomorrow as well.
And again, only of the "wires" in the neon lights up at all.
Regards,
Dennis
