Sister Ray
Member
- Joined
- Jul 10, 2008
- Messages
- 22
Hi A P, thanks a lot for the extensive reply!
I get the way the schematic vs. the Bloo kit works, and will take care of posting as you described in the future.
Here are the results of the questions you asked me, thanks once again for
taking the time!
[quote author="AnalogPackrat"]1) All tubes in and filaments happily aglow?[/quote]
Yes
R36: 1K
C13 Yes (I assume you meant C13 here?)
Output: Sowter 8940a
http://www.groupdiy.com/index.php?topic=234353#234353
Kind regards,
Sister Ray
taking the time!
Yes
Yes2) Neon lit?
Yes3) Did you measure each resistor prior to soldering it in?
R34: 22K/2W4) What values did you use for R34 and R36?
R36: 1K
R38 Yes5) Do you have an R38 [22k] and a C113 [510pF]?
Input: Sowter 4383-f6) What brand/model of input and output transformers did you use?
I'm in Ireland, and use the Hammond 369JX power transformer, have set it up as per this post, for 220V:7) Are you in the US or elsewhere?
238VWhat voltage is at the node between R16 and C7-C?
268VWhat voltage is at the node between R17 and C3?
96V (I assume you meant V3 here?)What voltage is at pin 1 (or 6) of V5 (the plate of the paralleled triodes)?
Kind regards,
Sister Ray
