skal1
Thanks syn , hows your machine getting on did you solve your problems ?.
i got 1 more ? , if you pot a pot between the two 47k you should be able to adjust the plate voltage of each triode is this correct.
so when reading the voltage supply to the triode do you take the reading from the junction of trim pot and 47k or junction of 47k and pin 1 ?
if you take reading from pin 1 and 6 and they are are not balanced , does this mean the triode sections can not be matched ?.
skal1
skal1
