S sonolink Well-known member Joined Feb 15, 2010 Messages 1,338 Location London-Madrid Oct 10, 2023 #1 Hi everybody, I'd like to be able to use 12ax7s AND russian 6NxP tubes on a pedal I have built some time ago. It's running 12ax7s at 9v presently. Would this solution be correct? Or would this one be preferable? Thanks a lot for your time and help! Cheers Sono
ruffrecords Well-known member Joined Nov 10, 2006 Messages 16,278 Location Norfolk - UK Oct 10, 2023 #2 The second one should work. The first one will not - you could just use a high warrage series resistor instead. Cheers Ian
S sonolink Well-known member Joined Feb 15, 2010 Messages 1,338 Location London-Madrid Oct 10, 2023 #3 ruffrecords said: The second one should work. The first one will not - you could just use a high warrage series resistor instead. Cheers Ian Click to expand... Thanks for your reply Ian!! Cheers Sono
merlin Well-known member Joined Aug 17, 2011 Messages 262 Oct 11, 2023 #4 Or put two 6NxP heaters in series
