[quote author="tubejay"]Wow, thanks for all the info!! I can't wait to dig into mine and get it all fixed up. It looks like you left the original resisters in there? I just checked out the Albini thread at his site, and it looks like they replaced them. I don't know though, I kind of want a cool colored sound out of mine, so I'm going to leave them to start with.
[/quote]
I haven't touched it except to replace dead tubes since I got it a little over a year ago.
And y'know what? As is, THE DAMNED THING WORKS! As is, the line amp blew me out of my doldrums with a Discman as a source both straight to output and monitored through the record head to my old college time Marantz 2225 rcvr. These things are like BMer's or Benz's, they just RUN no matter what you do to them, no matter how far out of whack they are. Word: locomotive! When you dial them in it's serious.
And the little one's aren't too shabby either. You can still get belts:
http://www.sprague-magnetics.com
Ask for John Austin, mention Vern Sauer's old Ampex parts inventory he purchased. There's a couple other places to I'd need to dig them up.
Whackamole:
What's the general opinion on the Ampex 1260 deck's mic preamp circuit? I've got one kicking around here and this discussion has got my interest up.
Same as the 960 in a different outfit, same heads as the 600 series portable pros w/a play head that's adjustable for 4 track stereo commercial tapes. Search here for 960, 601, 602 and 600. 900's et al are a pretty straight forward double 12A*7 preamp. You need to transformer couple both end tho for a working pre. Also get the manual linked earlier in this thread if it's not there pm me and I'll get you a pdf. If the heads are good and the deck's complete, make it work man! They are nutz simple to get together and working again. Buy 2! Send the heads to J.French. Sound wise they're just as good or better than the Revox/Studer G36, no ****. Fix it!!!
A 601-2 will knock your socks off. The transports are a little more complicated than the little hifi decks. Records way better than the G36. Sounds better than Tascam anything, better than Otari MX5050. Close to as serious as the big decks, standard two track width, not consumer 4 track on records.
All phones jacks output right off the tube for old 600-1K ohm cans. If you've got a complete deck try to make it work, if you've got a chopper make a pre, simple as that.
