Except the datasheet says 50A continuous. IIRC it is even higher for a pulsed current. The key factor is the 50 amps is only specified when the transistor is fully turned on when its Rds is less than 0.02 ohms. The other problem is getting rid of 50W from a TO220 package without exceeding a Tj of 175 degrees. That probably means a chunky heatsink with fan or water cooling.It could very well do 50A, the test was likely done with ~100us pulses
