thomasdf
Hello
I am going to build a passive monitoring controller using a Goldpoint rotary contacter.
My only concern is that I like mixing with VU meters and / or peak meter.
Can I simply route my monitoring controller's input in parallel to an output going to my VU meter driver?
Will that affect the monitoring signal or not? Will the VU driver circuit (JLM for instance) will change the level depending on rotary switch position?
A crappy drawing I made in case I am not clear :
Thanks a lot in advance
