I've done some testing now. It works well. It's completely quiet when there's no input signal (I'm used to tube amps :wink. I have only fitted a small heatsink, and that stays quite cool even when the amp's working.
I have also made a couple of measurements. For my testing I used a 2*15V 100VA toroid. The actual output voltage was 2*18V though, both with and without load. The DC voltage was around +/-24V at idle.
The maximum output voltage without clipping was 19V peak. The DC voltage dropped to +/-22.3V at that point. My load resistor is 8.33R, so the max. output power is 22W. The output looks like a perfect sinewave until the clipping point. Above that you get a strange looking waveform caused by the protection circuit I think (the SPiKe stuff). The frequency response is good. The output started dropping slightly above 100kHz, but that should be enough I guess...
The only problem I found was that the amp oscillated badly when the output was loaded by the resistor (and scope), and the input was left unconnected. Does anybody have an idea why? If the input was shorted, or connected to a signal source there were no problems.
I will get a 2*22V transformer to find out what the maximum output power actually is. I think 48-50W should be possible.
Best regards,
Mikkel C. Simonsen
Best regards,
Mikkel C. Simonsen
