living sounds
I've got a 9632 HDSP that I bought used which had a problem with the analog output. Doesn't matter to me since all I need is the AES input, but unfortunately that stopped working and so did the S/PDIF input, too. I might have accidentally - repairing another converter connected to it - sent too much voltage (something like 24V AC) into it. I replaced 4 capacitors with new ones (the slightly too big panasonic FC ones on the left), two of those looked a little damaged when I bought it. No luck, it didn't cure the problem on the output (noise, sometimes) or the AES input. The ADAT input is working fine, but the card shows nothing coming in from either AES/EBU or S/PDIF.
Is there an obvious part to try and change? Could the small transformers be sufficiently damaged by a very short overvoltage? Sending it in for repairs would cost more than buying another used one, and the trouble is - of course - that there's no way to test it while it's running. RME won't give me schematics either, of course.
