living sounds
Thanks! Went through the board several times, there is no reset generator looking like the one you linked to.
As for syncing, I think RME always designs in a way that has the signal reclocked by their SteadyClock (which restarts the clock once ever 1-2 sec I think) circuit, so there's probably additional circuitry vs. the reference design. It definitely doesn't simply slave to it.
There is just that one 74HCT04D on the board. One HCT4046. Two ADG451BR. Flash memory, the Xilinx FPGA and a Xilinx XC9536XL CPLD.
So if the HCT4046 is probably for ADAT, maybe it's time to try and replace the ADG451BR closer to the DAC? There are also a lot of SMT transistors, non of which looks compromised from the outside.
One more thing: The optical input only works only with ADAT signals, not with an incoming standard digital signal.
