bcarso
Some time ago On Semi announced some power bipolar parts with in-package isolated diodes. As transistors they are identical to the popular "Motoshiba Toshirola" 2SA3281 and 2SA1302 devices. The TO3P package has been modified to incorporate two more leads for the diode.
The part numbers are NJL1302 and NJL3281.
A fellow consultant sniffed at these because he said Why didn't they make some driver parts as well? which I thought was a trifle uncharitable at the time. I suppose you could use them as the driver parts as well, for that matter, although it's a lot of silicon for any but really high power apps.
Anyway, I see they are still being made, and I have an inquiry in to their tech support about some questions (like what is the degree of electrical isolation between the diode and transistor, and max differential voltage), but in the meantime I wondered if anyone in here has had experience with these puppies.
Used properly they should allow a significant improvement in amplifier performance, permitting one of the bugaboos of class AB design to be handled well, namely the time lag between the device die temp and the biasing transistor and the resulting distortion and/or destruction.
Although I'm getting increasingly comfortable with the fidelity of really good switchmode, I think there's still a place for linear.
