Anyone in Los Angeles to Help Install GSSL Turbo?
zachs
Salt Lake, UT
Looking for some help on this project if anyone is in Los Angeles... Please PM or email, thanks!
I've a GSSL that I've been using fine for a while now but want to wire this in. It seems straight forward enough.... just don't want to mess anything up  :eek: and I've got a few sessions coming up.
if you have pending projects that will require a gssl then wait until there is time to put it in and test. why risk messing with a working unit when there are projects to use it on.
Mainly due to the fact that the stereo image sounds much better and wider with the Turbo mod installed. It's switchable as well so if there is an issue, the switch should bypass... Looking at it more and seeing if I can just do it myself.
But I do get what you're saying.
it does? have you heard one with it?
Yep. Have heard a few samples and the difference was really noticeable. I mean, SSL Tech even shows how the regular GSSL is compressing more down the middle thus creating a less stereo sound.
