Pucho, Im actually thinking of doing that as well, now that I see how these pots react. (either that or changing their value...) I can only use about 1/4 of the dial before the level gets so high its distorting or clipping the converter inputs. (unless im really hammering down the compression knob)
To answer your question, when i wired the unit up the first time, I had different grounding points in the case. (similar to the last problem where i put an insulated post where a ground post should be) in this case, the top pin of R3 was no longer making it to ground, which is connected to R36... Insert wire=working unit. I popped in the other tubes i was using and they all work, (and actually sound better) as did the t4b. I'm still trying to figure out if I should put that resistor across pin 3 and 1 on the t4b (2.2Meg) Even in the reissue la2a from UA, i dont see a resistor placed there, and all the pics I've seen of everyones builds, I don't see i there either.
