APE EQ PCB (See video sample)
ForthMonkey
Turkey
€60 for one mono channel.You will get four frequency boards,four voltage follower boards,one PSU and one main board.Totally you will get 10 boards for one channel.
€100 for stereo set.You will get eight frequency boards,eight voltage follower boards,two PSU and two main board.Totally you will get 20 boards for one channel.
Shipping fixed to €7.
Video Sample
https://www.youtube.com/watch?v=V3iyq_F2kY0&feature=youtu.be
I re-designed.I'm trying easy to build,cheap and useful unit.
Freq_Board_Schema
https://dl.dropboxusercontent.com/u/91809016/APIsh/Freq_Board_Schema.pdf
Main_Board_Schema
https://dl.dropboxusercontent.com/u/91809016/APIsh/Main_Board_Schema.pdf
Voltage_Follower_Schema
https://dl.dropboxusercontent.com/u/91809016/APIsh/VF_Schema.pdf
PSU_Schema
https://dl.dropboxusercontent.com/u/91809016/APIsh/Power_Schema.pdf
Calculated Gain Resistors
https://dl.dropboxusercontent.com/u/91809016/APIsh/GAIN_RESISTORS.pdf
Front Panel
https://dl.dropboxusercontent.com/u/91809016/APIsh/APE_FP.rar
Not opamps, they are unity gain buffers. Look at the schematic in this post. At the bottom there is a dashed rectangle. This three-transistor circuit is placed for every one of those 'A's in the schematic. You could use an opamp buffer of course, signal to +, - connected to output.
Thanks! I got it.And i made low mid band with this buffer and it's good.I added first post.
But now i have help.For design i used TL072 but i will use 2520.It's discrete.I need to convert it to op amp schema like other LTspice op amps.Cause 2520 is big.
Spencerleehorton said:
Is this a 550b eq?
Could you post some pictures?
Regards
Spence
I don't think there are many pictures to post since this project has just started and there's nothing more available than the schematics.
Is this a 550b eq?
Regards
Spence
Yes there is only circuit now.And now i'm trying to combine all section.I will add full circuit and PCB.Then i will wait for parts. ;D
Very interested in this as I have built 4 x api312 and want some eq units to compliment them.
If your able to send me any info on all this that would be fantastic.
4 band dual concentric pots I do need to source.
Regards
Spence.
Regards
Spence.
Now i re-draw circuit.
Now i finished design.I will create two PCB.One for switches and one for main.For now it's unbalanced but i will add in&out transformers.
:eek: Someone said that i will make PCB for you but he is gone...I don't know why...I think i have to do it my ownself.I'm still learning.I hope i can figure it out.
I added control board.It doesn't fit 500 series but still small.Actually i can't find dimensions of 500 series.This size is ok?
Size: 2.349 x 5.089 inch
