saxmonster
- Joined
- Jan 3, 2012
- Messages
- 534
pasarski said:It's going to be more like an ELA M circuit but it'll sound good with Tim's capsule, it's amazing capsule. But you have to modify the PSU to provide for 55-60V polarization voltage (which means 110-120V B+). Learned that the "hard way" myself. You'll find means to do that searching here. Changing R7 to 1.8K (ELA M value) starts to make sense also with 110 B+. All the capacitor swaps may not be necessary. When you get the mic check first what's in there, stock parts might be fine, they've changed through the years.
What happen with the "hard way" Did you ruined a capsule?
I am getting one of Tim's capsule and my pins 1 & 4 on the stock apex 460 PS are reading 143vdc. I am going to swap out the zeners and lower it to 120-125vdc. Is this a safe range? What happens if its a little hotter or below 120vdc?
-Scott
