Hi
Same story :grin:
I finished two Fabio API. It works in first moment :grin:
Used OEP ans Profile 4804
I make version without servo out, unbalanced out but with socket for NE5534.
I find two pots 22K Rev log in old broken H-H VS Musician guitar amplifier.
Have one API 2520 (Seth sold me), two BTI OA400 (gift from Seth) and mine 2520 and Melcor (unfinished)
I test 5534, 2520 and BTI. Sounds different.
Havent any hum if I test outside chassis.
Because I make test on the bench I didnt put switches for +48, pad, phase, and line.
I used Fabio PSU and I will try (if we cant find better solution) to connect with 5V regulator after 18VDC or maybe before LM317. I didnt use 10ohm between 2200uF
Here are some voltages:
Before diodes ? 21,6VAC
After diodes ? 28VDC
Before LM317 for phantom ? 55,6VDC
I saw only 44,8VDC on +48V connector.
I must change resistors. Fabio put 240ohm and 8,2K. Do anyone have value of resistor (instead 8,2K) to see 48VDC.
Also I finished original board API with Jensen JT-110K-HPC and Profile. Used PSU from Dual Fabio API
Works nice. I check with Sennheiser 441 and use 2520.
Any suggestions?
Thanks to Fabio, Goran for OEP (birthday gift), Joe (for relays), Seth for two BTI (gift), Frank for Mill-Max and to all who teach me about this.
Duka
