pmroz
peter... or anyone..
are Jay's and Fabio's (Peter C layout) 1731 PCBs the same?
I use the Melcor amps in 2520 place, just add another cap (100pF) from out to -in in the Melcor so when I plug in the API board I´ll have 220pF since there´s 120pF there for the 2520...
That's a nice approach. And who knows, it was just the way 1731's were used ? (with a higher R*C-product on their gainsetting-network). 20k&220pF, still an OK bandwidth. I'll add the cap & see how it behaves for low gain-settings.
exactly right. I'm waiting for the scope for these (and 'BC's) before boxing them, to make sure they 'play nice'.Hopefully those with working designs are not misinterpreting the slight oscillation at low gains as part of the character of the 1731!
A standardized test with optimal values on input and output is a great idea.And let's agree on the conditions.
Just a proposal:
* raw opamp, so no TXs in front or after
* some Hi-Z biasing-resistor to gnd (say 1MOhm)
* 22k & 22k gain-resistors (gain of 2),
* feedback-cap of certain value (under discussion),
* internal cap C3 of certain value (under discussion),
* supply +/- 15V,
* resistive load of ... Ohm
No problem. And corrected for the TX-ratio, the load could be made identical, so in essence same setup. Note the 990/AES-paper can't be downloaded as far as I know but be requested @ the nice folks @ Jensen. They send it out free of charge.Peter, i hope i wasn't misleading about this in above post.
I'd love to test opamps only, but the best i can figure is on the pres with out trafo and hi-z in. I'll check that Jensen paper, thanks for link.
Well that explains it... I'll try an email. Thanks Peter.Note the 990/AES-paper can't be downloaded as far as I know but be requested @ the nice folks @ Jensen. They send it out free of charge.
I'd like to discuss that 1731-circuit a bit more, so that we're understanding what's actually going on there. Shall we move that to a separate thread or keep it here ?
So far mostly about a gain of 2 (equal gain-setting resistors). Unity will make it of course 'even worse'.How low of gain settings are we talking about?
Thanks, that'd be nice. These are 'originals', right ? We were wondering whether the Melcor-DOA in its original dimensioning had ringing/osc as well at say gains of two. Let's hope that unlike the 2.5.20 there's only one original 1731-dimensioning :wink:I have a couple of Melcors racked up if anybody wants some lab results.
Let me know what you want to check.
Thanks for the response.I think its a very good idea to standardize the test conditions as much as we can for testing both the 1731's and 2.5.20 designs. I suspect most of us are using both op-amps in the non-inverting configuration. So, here's my take on the conditions:
As long as the loads are corrected by the squared TX-ratios it'll be OK, OK ? The 1MHz peak won't be too visible after the out-TX, but I figure it'd be fine to load the TX as usual after the TX and put the scope-probe before the output-TX, agreed ?* raw opamp, so no TXs in front or after
This is good but may be difficult since most boards will be setup with
transformers. If we can test without all the better.
OK* some Hi-Z biasing-resistor to gnd (say 1MOhm)
If you're talking about the resistor from the non-inverting input to
ground I'd recommend using a 20k.
You're right, we shouldn't stop once (if) the low-gain issue has been solved. Maybe the consequence of a certain fix is that at the highest gains there's not enough BW, so check indeed.*22k & 22k gain-resistors (gain of 2)
On my test jig (I built one to test my 2.5.2.0's) I use a 12 position
switch. This allows repeatable gain settings from 2-100 (6-40db)
We should be testing at the full range of gains. Although, for starters
this would be fine to get over this initial oscillation problem. I agree
the most important now is low gain for the 1731 (gain of 2).
OK* feedback-cap of certain value (under discussion),
I suggest 120pf for the 2.5.2.0 and 200pf for the 1731s.
I hope to make a second one of the upcoming days and will put the other value in. Or I'll modify the first one.* internal cap C3 of certain value (under discussion),
Let's see if someone has success with my recommendation to increase
this to 470-680pf (on 1731's with oscillation problems). Also, lets see
if others who have built the 1731s have this issue as well. Otherwise
lets keep the schematic as original to begin testing.
Anyone has some quiesc.current-consumption values ? Mine seem a bit low (8mA ?)* supply +/- 15V,
Yes
OK* resistive load of ... Ohm
Let's keep it at a easy load of 20k. I set my jig up to
switch to 600 ohms as well to test full drive capability. But for now to
keep is simple 20k would be a good place to start.
OK* capacitive load of ... nF
Let's wait on this one!
That both a pity and promising - not too much sensitivity for the transistors, as should.I should be able post my simulations in the next 2 days. I started with standard evaluation transistors but ended up using the BC550, BC560, BD135 and BD136 models. Simulations were essentially the same for frequency response. Both had the nasty top end on the 1731 with the bump and shelf at low gains.
Fully agreed. But your sims together with the scope-oscillations give faith in the sim-results.We should be careful with simulation results. They can be good a tool in predicting circuit behaviour if they're setup right as seems to be the case with the bump in the 1731. But the bench is always the place to go for the real deal!
... and an older Melcor-thread has joined I'm afraid (my fault, today :wink: ) must admit that's a bit less elegant. I've added crosslinks, let's hope that helps for now.I'll follow where ever you decide to take this topic. At this point it seems to be jumping back and forth between both op-amp designs.
