Fabio, if not using relays, i need another switch for DRL_HZ, correct?
Don't see 'NOTE 3' anywhere. only NOTE 1.
If i use relay here, it auto-switches when plug is in?
If so, maybe this is the only relay i'll use.
So what values should be used for R3 and R4? Thanks!
On BC, is it correct that if R3 = 20k, sum of R4 + R5 should equal 20k?
