Greg
[quote author="BackHand"]So you compaired you're DIY 3124 against the original API 3124 and you're DIY did not sound the same?[/quote]Correct
[quote author="BackHand"]Do you have the same OP Amps as in the original?[/quote]
The opamp that I was using was actually an older 2520 than what was in the 3124. I also compared it to the Melcor 1731, so that one will definitely sounds different.
[quote author="BackHand"]In what whay whas this DIY version diffirent in sound from the original?[/quote]Let me first say that the 3124 is really not the same thing as an original 312. It uses a different 2520 and a different input transformer. So I wouldn't say that the 3124 is an original 312, nor would I expect it to sound like one. Even my DIY version will have a different sound than an original 312 since I'm using a different input transformer. But regarding the 3124 and my DIY 312, the DIY 312 sounded a little more rich in the mids, but wasn't as bright at the top. That's the main difference.
