mikefatom
That's excatly what I ordered!
guitarguy12387 said:Ok got a chance to do some more testing today. And... got MORE weird results.
After double checking all my component placement again and cleaning up some solder joints, i tried tying pins 6 and 7 of the input tranny together and taking them directly to star ground point. I decided to do this because i had noticed that touching the can of the tranny significantly reduced all the noise at high and low gain values.
Here's the results: I pretty much get great sound at all gain settings except for the third position from counter clockwise (lowest gain) which still has lots of clicking/humming (oscillation i assume). Another weird thing is that the gain settings below this one (settings one and two) both are very high gain... which seems weird to me.
I have double checked (with a multimeter) that there are no shorts on any of the gain resistors and grayhill switch. I have also checked my R values many times. I cannot figure it out!!!
guitarguy12387 said:AHAAAAAAA! Finally!
So i removed the output transformer (even though i had already tried spacing it from the PCB by as many as 2 nuts), like you suggested, and perfect sound!! At all gain stages. ;D
So yeah... i stuffed the resistors as you mentioned (and i plan on mounting vertically), but i have been testing horizontally. I guess i just assumed fully CCW was lowest and fully CW was highest gain settings.
Ah... i'm so glad that... after a solid 6months of working on this thing... it finally works! Ha.
Thanks again to EVERYONE for all the help. Especially bob... thanks for your patience and help. I will be buying some more of your boards soon
mikefatom said:could someone tell me what the purpose of CDI1 (18pF) is?
From what I understand, it is simply a tone shaping cap. i.e. reduces bass at the DI input. Am I right?
The -3dB point of that RC (RDI1 and CDI1) network seems to be around 4kHz.
Is there a reason for the 4kHz figure?
bobschwenkler said:Speaking of Fabio's DI's, do people have theirs working? I have 4 wired up with DIs in my 8 channel box and all of them are really noisy. I haven't spent a single moment troubleshooting them yet... I wonder if other people have run into the same isue?
jsteiger said:I just looked briefly and didn't look at the x-fo, but shouldn't the 6K8 resistors should be parallel with the input Hi and Lo, not series?
Jeff
brazilianwonderboy said:Right then, I've got my first PCB layout designed for my preamp and I would greatly appreciate it if anyone had any tips or hints regarding it. An image of the layout is attatched. Just some notes on it. I have included a footprint for a Lundahl LL1587 Input & a Lundahl LL1517 Output as well as connections in case I decide to use a different output traffo. There is an attenuation pad after the output. The traces are all 1mm.
rrs said:Well almost finished my first API.
Just waiting on opamps from Fabio. ;D
Wondering what the maximum voltage the OpAmps can take? I've heard of a few people blowing theres and wondering what are the main causes of this???
bobschwenkler said:If you want something that's similar to original API transformers go to Cinemag and the the 75101A(suffix PC for PC mount version), and the CMOQ2-L output transformer.
I don't know a whole lot about Lundahl's line, but the 1538 is a popular choice as a cleaner input transformer.
What do you mean what about the ohms?
