rafafredd
Man, that´s absolutely beaultiful work. Can´t believe it´s first time DIY. You are a natural! Go for more!
#1
I'm using Ceramic Caps I pulled from the old Yamaha board for the Zobel & Feedback Network...
Should I upgrade these & to what?
Also, what sonic improvement could I expect if any?
I've seen mention of:
COG/NPO
Film ? type ?
... & while I'm at it, what are the Ceramics with a BLACK DOT
#2
I'm using .1 Monolythics to bypass the 220uf caps on the power supply rails feeding the Op-amps...
I've seen others use Polyester films for this...
How do the different types effect the sound
#3
I'm using output trannys on every channel & love this thing on drums but I feel I may like the Kick & maybe the snare to have the option of being a little LESS Colored from the OT's...
The problem is I'm not using an output coupling cap so the switch would have to add a coupling cap and at the same time bypass the OT.
Any ideas or tips?
#4
I'm using an AMVECO 22V 1.590A (35 VA) Power Tranny...
& wondered if it gives me enough headroom for a punchy drum pre?
& MOST Important - What size & TYPE Fuse should I have in this thing BTW, the Power Supply regulators DO NOT get hot at all... barly even warm.
47pf & 20k in the feedback
22k reverse audio taper pot
If you can, post your questions & results in that thread.
I'm very interested to hear what you think of it in the API 312... others might be into it as well.
Kevin
mattnj said:Is there any way that you can share the PCB layout for this project? Thanks,
-Matt
