are these polystyrene caps good for mxl 603s mod?
Jonkan
Sweden
I cannot find any other polystyrene caps in sweden except these that might be suitable. Apparently I have to order at least ten, but I only need two, so before I shell out the money I was wondering if these might be good candidates for Gus mxl 603s mod?
Any thoughts?
edit: the link i posted doesnt work, so you have to manually search for the product number, which is 113-320. Just go to www.rsonline.se
, enter the number and press "SÖK". The top left corner.
The product info is in english,so dont be intimidated by the swedish on the frontpage. :wink:
thanks!
/Jonas
oops, sorry... I will try to fix it!
thanks for pointing it out jakob!
edit: anyone that knows how to link from RS? I cant figure it out.
Anyway, the productnumber for the cap is: 113-320
you should be able to manually search for it on their homepage www.rsonline.se
just enter 113-320 in the field on the top left and then press "SÖK".
/Jonas
problem solved!
I found some nice polystyrenes that probably will fit at farnell, yay!
Now im wondering,
will wima mks2 capacitors work good for the 0.22uf caps in Gus´s mxl 603s mod?
thanks for any help!
/jonas
[quote author="Jonkan"]edit: anyone that knows how to link from RS? I cant figure it out.
/Jonas[/quote]
You can't...
They choose the Broadvision product for their online-catalogue and CRM ordering facilities...
You can't link to a Broadvision session
