it was my fault, i tried to edit a post using a Direct Access Storage Device interface with fixed block architecture, the result was a revised ECHS mitigation,
this limitation by using 128 or 240 instead of 16 heads, simultaneously reducing the numbers of cylinders and sectors to fit into 1024/128/63,
this was fixed by rebooting the drum memory devices or the IBM 2321 Data Cell, but actually 512×63×256×1024=8064 MiB yields what is known as 8 GiB limit In this context relevant definition of 8 GiB = 8192 MiB is another incorrect limit, because it would require CHS 512×64×256 with 64 sectors per track.
during the third pass into the malware diagnostic program process, a bug was spotted at this location>
