maxwall
- Joined
- Nov 17, 2004
- Messages
- 1,134
Objective : PSU for the AT4060 tube mic (cardioid only) , 6922 tube.
AT4060 PSU Link HERE , but the document is unreadable unfortunately.
Looking for a At8560 tube mic psu pcb layout or detailed pics would be a big help.
Original Thread HERE , referenced from Lab discussion.
Possibly a schematic like this can be used to create a new psu for the At4060 with minimal circuit changes in B+ (120vdc) , since the At 4060 mic accepts 120vdc Plate voltage and 6.3vdc Filament voltage. Plate voltage below would be single output Mosfet (IRF740) regulated at 120vdc with current requirement from 5-10ma min. The 6922 tube for the filament has a current requirement of ~ 300-365ma. Also regulated by NPN pass transistors found the original AT8560 PSU schematic, but in this case LM317 is used , in some instances as a current source regulator as illustrated below in PSM169 heater supply. The NTK heater supply below is voltage based regulator. Yes, there is a difference.
Having the PSM169 psu that originally powered a 6205 sub-mini tube filament supplied ~ 100ma, However , I'm tying to convert the LM317 CCS ( constant current source) filament circuit in this supply to deliver more current for a 6922 tube , but having difficulty stabilizing the filament voltage to 6.3v (+/- 10%) after changing the 15ohm 5w resistor to 3.9ohms 3w (R1). CCS Calculator HERE This resistor is positioned on the adj (pin 2) leg of the LM317 regulator - see circuit below. I have also tried different small power transformers ranging from 8vac up to 16vac from 400ma to 1amp. Apparently, the filament transformer must be 5v higher than what is required on the Vout according to LM317 operating specs. I do not have access to a schematic for the PSM169 and will have to draw one out - now added. As a Dummy load,rather than a large power resistor, and without placing a costly 6922 tube at risk, I test only using one 12au7 tube tapping only the filaments in parallel (pin 4,5 tied & pin 9) configuration which simulates a ~300ma load, close enough . Note : HV AC not applied to the HV section of the psu pcb for B+ during bench test - filament only. PSU circuit below is Rode NTK tube mic which powers a 6922 tube. Closest circuit I could find that used the 6922 tube, and I like the modern Mosfet regulator pass transistor regulator rather than a BJT NPN pass transistor. The Audio Technica At4060 tube mic utilizes a 6922 tube, not a 6DJ8.
