samplebias2
Active member
Asking for general ideas here since nobody probably has an EMS vocoder-
As you know, a vocoder imprints the sonic signature of one source, onto another i.e. robot voice (speech onto synth tone).
My EMS 2000 vocoder has an "output select" switch that lets you hear the carrier, modulator, or vocoder output. Only 1 at a time.
After the unit warms up, my human voice starts fading into the vocoder sound intermittently, then stays on..
I have replaced that 3-position switch, and the "pause stuffing" switch ( this feature blends those two sources, voice and vocoder if that's what you want to happen)
My question is, in general- what WAY could two separate signals merge once the unit warms up- corrosion or some way the signal can "jump" from one to the other? IC chip? Unit is from 1989 and was barely used. Hoping to arm my tech with more info when I bring it to the shop when it's my turn in 3 weeks.
