Siegfried Meier
Hey guys,
We've got this issue at the studio and it's plagued me for years. Our snake in the tracking room runs into the control room and is connected directly to a bantam TT patchbay - it's around 100 feet long. The snake ins are normalled to the mic preamp inputs, but it also allows me to patch around in the control room as opposed to repatching at the snake. Now, certain dynamic and ribbon mics, when connected to various preamps emit a hum/buzz with higher gains. The buzz not only increases, but seems to change tone as the preamp level increases.
A few things kill it. One, if I bypass the snake and patch directly into my preamps - it's obviously not ideal, because when I test I'm running through the doors and can't close them properly for tracking. 2, if I use a Cloudlifter device, which is that little 25dB gain boost box that requires phantom power - the hum/buzz is completely dead. Also, this never happens with phantom powered mics either.
I've checked and tested all my ground points on my patchbay but cannot for the life of me figure out what might be happening. Is it just the fact that it's a cheap shite snake? Should I rip it out and install a Mogami or something of a higher nature? I've been told it's capacitance problems with the inexpensive cabling. But why is the Cloudlifter completely eliminating it then? Maybe I should just buy 24 Cloudlifters and use them as needed...? :-O
Any thoughts much appreciated.
Sig
Sig
