mitsos
- Joined
- May 4, 2007
- Messages
- 2,886
New trafo 10K:150+150
Same format as the last one, P-S-P-S-P, primary wound with 39AWG, secondary with 33AWG.
Thinking back I could have maybe split the secondaries further or done them bifilar, for better balance. but anyway. Shield was 40AWG wire.
Pri1 = 7 layers of 174 turns
shield
Sec1 = 5 layers 85 turns
shield
Pri 2 = 6 layers of 174
shield
sec2 = 5 layers of 85
shield
pri 3 = 7 layers of 174
total pri = 1218+ 1044 +1218 = 3480 turns
total secondary = 425+425 = 850 turns
turns ratio:
Sec in series= 4.09:1 ,
Secondaries in parallel = 8.18:1
Inductance
Pri L (couldn't get good reading, might be 63H, calculating from 600 Ohm secondary (4.45H) gives 74.45H)
LeakageL (one sec shorted = 54mH, both shorted = 16.9mH)
DCR = 540 Ohms
Capacitance across pri
140pF (sec open)
140pF (sec shorted)
(16.9mH and 140pF resonate at 103.5KHz? Is that correct?)
Looking better? I have a new 10K:10K to wire up and test as well.
Question, the only way I could get capacitance readings on this was connecting the shields to the meter common (along with the end of the winding). Otherwise I get negative readings.
shield
shield
shield
shield
turns ratio:
Inductance
DCR = 540 Ohms
140pF (sec open)
140pF (sec shorted)
