4u7 in this case.PRR said:The 2db@10Hz - 4db@15Hz bump on your plot suggests a non-infinite capacitor, probably blocking emitter-follower DC level. Knowing that cap's value adds clues.
I think there was a lot of cable to the preamp. Then there's the RFI bits on the mike preamp. The upturn in the Red curve above 100kHz is a measurement artifact cos the signal level is low and bandwidth high.There's also a small cap somewhere, probably on secondary, possibly just secondary self-capacitance (though if load is really 2K, it suggests a lot of stray C).
The starting point is that the B/H curve inflects as soon as DC shows its nasty nose, less with iron than Ni, so basically it's a "linear" process by which THD increases as soon as DC comes in.mitsos said:how do we know how much DC an ungapped trafo can take, is there any rule of thumb to get a starting point?
Some might say that's why the old ones sounded better! 8)abbey road d enfer said:This will be obtained at the cost of quite a high 2nd harmonic THD.
mitsos said:Ian,
On the carnhill ungapped output description you write that it's not suitable for DC on the primary, how do we know how much DC an ungapped trafo can take, is there any rule of thumb to get a starting point? My understanding is that there is a grey area, the trafo could handle a bit of DC before inductance spirals down.
Hello Ian
I think you might get away with this.
The current will tend to saturate the Mumetal part of the core but certainly
won't touch the M6 part.
I think however that it would only partially saturate the Mumetal. Any
result will be loss of inductance which would cause an increase in the LF
cut off frequency.
Best regards
Brian Sowter
Primary inductance exists by itself. The secondary, being unloaded, reflects nothing on the primary.david-p said:Does not primary inductance also include the reflected (transformed) inductance?
Yes, primary and secondary exist on their own. That's why you can use just one winding of a transformer as an inductor.Can they be separated?
Many mic xfmrs are intended to be loaded by a much higher load, check tube mic pres - the secondary goes directly to the grid without a grid leak resistor.Why not make the determination by loading the secondary with the intended resistance (usually 2k in the case of microphone inputs)
This is indeed what many people do; that's called indirect measurement. It's correct for someone who designs mic pres but does not want/can't design a mic xfmr. Someone who designs xfmrs must assess the primary parameters, i.e. inductances and DCR, some other parameters are measured indirectly, such as coupling factor/leakage inductance, but it is always preferrable, on a scientific point of view, to measure primary parameters directly, not indirectly, particularly in the case of xfmrs, which have a high level of interaction with the associated circuitry.and doing a frequency response measurement to determine the LF and HF 3dB limits?
Indeed, and that's a necessary complement to the primary measurement.This would also show up any resonant effects and might be more useful to designers.
I'd rather have the winding info for the PA-5946!! ;DCJ said:let me know if you want more formulas, yuk,
performance in specific test situations
I would be interested in seeing such results tabulated for the various microphone o/p transformers that are currently offered for sale. As already noted, the manufacturers offer little data beyond turns ratio and price.
Err.rrh! I think Bert stole this from Mr. Williamson. see p18 ;Dtrobbins said:Bert Van der Kerk prepared details on diy Williamsons, and came to the conclusion that 5V mains was the most practical measurement for prim L.
