emrr said:I got to throw this on an inductance meter with a 120 Hz test, no load, and saw:
2487 Henry on the 30K winding
34.57 Henry on the 500 winding
(that's UTC LS-51)
C'mon man, I bet you have piles of transformers, measure a few more!
Ouch!emrr said:I don't own an inductance meter
abbey road d enfer said:LC meters can be justified only for rough evaluation and production control.
As has been already mentioned, inductance varies considerably with frequency and level.
What is the impedance of the generator you use for your test?lassoharp said:As has been already mentioned, inductance varies considerably with frequency and level.
I do have a high level input transformer from radio transmitter that gives a relatively paltry L reading using a handheld meter, yet when swept shows solid bottom response that doesn't match the meter's numbers very well. This particular transformer was for some reason the exception to all the other input transformers I measured and the only difference I can think of may be in level handling capability.
What is the impedance that drives the transformer when you do a sweep (quote: "yet when swept shows solid bottom response" )
For 200 ohm impedance (mic input) you need about 5H for good 20Hz response
Which would be correct for jurassic impedance matching but not for today's bridging. Today, the highest source impedance in professional environment is microphones and passive DI boxes; all other sources are typically 50-120 ohms.lassoharp said:What is the impedance that drives the transformer when you do a sweep (quote: "yet when swept shows solid bottom response" )
The sweep was actually done by Doug so I would assume source was set to rated pri Z = 600r.
Is it possible that the sweep has been made at such a level that the UTC started to saturate? Has it been made as a direct compare, or is it possible something has changed in the test set-up?My handheld gave reading of 4.5 and 5H @ 120Hz for each of a pair - this being on a "600r" pri.For 200 ohm impedance (mic input) you need about 5H for good 20Hz response
The sweep Doug did looked as good or better on the bottom than, say, a UTC A-10 which will give a meter reading of 15-18H on the 500/600 tap.
abbey road d enfer said:What is the impedance of the generator you use for your test?
abbey road d enfer said:Which would be correct for jurassic impedance matching but not for today's bridging. Today, the highest source impedance in professional environment is microphones and passive DI boxes; all other sources are typically 50-120 ohms.lassoharp said:The sweep was actually done by Doug so I would assume source was set to rated pri Z = 600r.
I don't think I've got it backwards. Lassoharp wrote: "high level input transformer from radio transmitter that gives a relatively paltry L reading using a handheld meter, yet when swept shows solid bottom response" then compared it to "UTC A-10 which will give a meter reading of 15-18H on the 500/600 tap" but doesn't fare as well on the sweep.emrr said:Anyway, the interpretation you have is backwards; what lassoharp said was the iron doesn't look so great with the handheld LCR meter tested open at 120 Hz, but looks fine on my AP with a 600 source into a 100K load.
